system.hostname changes
  • pras_sawant
    • Feb 2020
    I have trigger which look for hostname changes on redhat linux , my test scenario is as follows
    log in to ec2 instance as root and change the hostname with command hostname (new hostname) , expected result is to see warning on dash board on hostname change
    It only visible on dashboard once I do the zabbix-agent restart , can you advice how can i see on dashboard without restarting the agent
    my trigger is [Template:system.hostname.diff(0)] > 0
  • pras_sawant
    • Feb 2020
    Any views champions
    • Atsushi
      • Aug 2013
      • 2028
      You do not need to restart Zabbix agent. If you want to detect the change as soon as possible, you can shorten the monitoring interval for checking system.hostname.
      • pras_sawant
        pras_sawant commented
        Thanks I will check this , currently interval is 1h
