Has anyone been able to use Zabbix to access an Azure web application, post azure authentication?
We have a webpage which shows the status of a job, I need to query that page for something like "ok". The problem is, the webpage is secure so you need to authenticate first.
Finding it difficult to do this. Would like to do this preferably without any zabbix agent or proxy in Azure.
Thanks.
Thanks.
