Problem importing data for installation
  • mahmood
    • Mar 2020
    • 24
    Here are the steps that I took to install zabbix on ubuntu 18.04. In the middle of the process before launching web installer, it seems there are some problems.
    # wget https://repo.zabbix.com/zabbix/4.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_4.0-3+bionic_all.deb
    # dpkg -i zabbix-release_4.0-3+bionic_all.deb
    # apt install zabbix-server-mysql zabbix-frontend-php zabbix-agent
    # mysql -u root -p
    mysql> CREATE DATABASE zabbixdb character set utf8 collate utf8_bin;
    mysql> CREATE USER 'zabbix'@'localhost' IDENTIFIED BY 'MYPASSWORD';
    mysql> GRANT ALL PRIVILEGES ON zabbixdb.* TO 'zabbix'@'localhost' WITH GRANT OPTION;
    mysql> FLUSH PRIVILEGES;
    mysql> quit;
    # cd /usr/share/zabbix/zabbix-server-mysql/
    # zcat ./data.sql.gz | mysql -u zabbix -p zabbixdb
    Enter password:
    ERROR 1146 (42S02) at line 2: Table 'zabbixdb.hosts' doesn't exist
    I didn't continue then. Any guess?
  • Atsushi
    • Aug 2013
    • 2028
    Check the instructions on the download page.
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    The file data.sql.gz is not used. It is not included in Zabbix official package. Use the file create.sql.gz to create the tables on the database and insert the initial data.
    ex.
    # zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbixdb
    • mahmood
      • Mar 2020
      • 24
      There is no such file
      # ls /usr/share/doc/zabbix-server-*
      changelog.Debian.gz  copyright  NEWS.Debian.gz  README.Debian
      • mahmood
        • Mar 2020
        • 24
        OK. I tried the 4.4 from the documentation site and I can see create.sql.gz now.
