Total bandwidth (incoming+outgoing)
  • W3SERVE
    • Aug 2006
    I have a few questions:
    1. Is there a way to display the total incoming and outgoing traffic together?
    2. Is it possible to send a message when a value suddenly increases for more than 15 minutes or something?
    I like Zabbix, but it is very bad documented...
  • W3SERVE
    • Aug 2006
    I've used Cacti for two days now, and within 5 minutes I created the graphs I wanted. It should be zo simple...
    I just want one graph containing:
    incoming traffic
    outgoing traffic
    And a way to display the total (incoming + outgoing traffic). This should be possible... Please help me!
    • sauron
      • Jan 2005
      • 215
      Very simple.
      create 2 items with incoming traffic + outcoming traffic.
      Set at both custom multiplier as 8, units as bps and store type as delta per second. At next step create graph with this items.
      PS Please use /dev/hands & /dev/brains.
      • W3SERVE
        • Aug 2006
        Ok, but is the total traffic displayed in this way?
        • sauron
          • Jan 2005
          • 215
          This display two graphs. If you need one graph use avg item.
