Monitoring two instances of same application on the same server
  • drewblin
    • Feb 2020
    I created a template for monitoring Redis. Connection is set using macros - IP and port.
    But ran into a problem. I have two copies of redis running on the server - on different ports.
    How can i monitor the same template with different macro values be added to one node?
  • jiri
    • Mar 2020
    You can't. We do so by creating virtual nodes (one for each app instance).
    • Hamardaban
      • May 2019
      • 2713
      You can create a template that finds all installed versions of the service and creates the necessary objects. Look towards LLD.
