Actions and conditions
  • cerasus
    • Mar 2020
    • 24
    Suppose I have a discovery rule that:
    • Gets model number via SNMP
    • Gets system.uname via the agent
    Suppose I now want to create an action with the following condition:
    Received value contains X456
    AND
    Received value contains Linux
    Will that work? It seems that Zabbix may compare the first received value (let's say from the SNMP command) with Linux, which will not match. And then the whole condition will fail?
    I see this in the documention: https://www.zabbix.com/documentation...ion/conditions
    Service checks in a discovery rule, which result in discovery events, do not take place simultaneously. Therefore, if multiple values are configured for Service type, Service port or Received value conditions in the action, they will be compared to one discovery event at a time, but not to several events simultaneously. As a result, actions with multiple values for the same check types may not be executed correctly.
    Is there a reliable way to do the above two conditions?
  • Hamardaban
    • May 2019
    • 2714
    Understand when and why "events" occur . What is the source \ cause.
    And keep in mind that each event is independent of the other.
    • cerasus
      • Mar 2020
      • 24
      Can you be a little more specific?
      • Hamardaban
        Hamardaban commented
        You got it right. the problem is not solved in this way.
