using awk and $ in agentd.conf
  • riegersteve
    • Oct 2004
    • 68
    here are the relevant lines from zabbix_agentd.conf
    UserParameter=descriptors.available,awk '{print $3-$1+$2}' /proc/sys/fs/file-nr
    UserParameter=descriptors.error,awk '($1-$2)>(.9*$3) {exit 1}' /proc/sys/fs/file-nr
    [root@stg2 log]# zabbix_agentd -t descriptors.available
    awk: cmd. line:1: {print -+}
    awk: cmd. line:1: ^ syntax error
    descriptors.available [m|ZBX_NOTSUPPORTED]
    [root@stg2 log]# zabbix_agentd -t descriptors.error
    awk: cmd. line:1: (-)>(.9*) {exit 1}
    descriptors.error [m|ZBX_NOTSUPPORTED]
  • raminix
    • Jun 2006
    • 37
    I was a bit intrigued by this one and why it won't work. I was able to replicate the error and could not figure out a way to get it to work directly from the conf file. Both enclosing the command in back ticks and reversing the order by catting the file to awk failed. However, you can get around this by putting together a short shell script such as:
    #!/bin/bash
    ## descriptors.sh
    ## Called by zabbix_agentd, takes an aergument of
    ## either "avail" or "error" and returns a value
    ACTION=$1
    if [ "$ACTION" = "avail" ]
    then
    elif [ "$ACTION" = "error" ]
    then
    fi
    and then call it as such:
    UserParameter=descriptors.available,/path/to/descriptors.sh avail
    UserParameter=descriptors.error,/path/to/descriptors.sh error
    And that should do the trick.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Change
      to
      UserParameter=descriptors.available,awk '{print $ 3-$ 1+$ 2}' /proc/sys/fs/file-nr
      UserParameter=descriptors.error,awk '($ 1-$ 2)>(.9*$ 3) {exit 1}' /proc/sys/fs/file-nr
      ZABBIX 1.1.2 won't have this problem.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
