Web Monitoring - Get button field for login step
  • Krapoto
    • Mar 2020
    Hi everybody,
    I'm trying to configure a web monitoring for a website on Zabbix 4.2.4.
    The first step which consist of checking the web access is OK but I have a problem on my second step : Check Login.
    I'm unable to identify the Post field for the "button Login".
    The html Code part is the following :
    HTML Code:
    <button id="bouton2" type="text" onclick="getElementById('loginform').submit()" onfocus="BoutonFocus('bouton2');" onblur="BoutonBlur('bouton2');" class="bouton">
                                        Connexion                                    <!-- <table border="0" cellpadding="0" cellspacing="0" onmouseover="BoutonFocus('bouton2');" onmouseout="BoutonBlur('bouton2');">
                                            <tr>
                                                <td><img src="/img/butleft.gif" id="bouton2left"></td>
                                                <td id="bouton2center" class="boutoncenter">Connexion</td>
                                                <td><img src="/img/butright.gif" id="bouton2right"></td>
                                            </tr>
                                        </table> -->
                                    </button>
    Can someone help me to understand where is the value that I have to get in this Html block because I don't see any "name field" ?
    Thanks a lot !
