Zabbix 5.0 alpha2
  • incama
    • Jan 2015
    • 67
    Zabbix 5.0 alpha2
    Is there a reason why there is no zabbix-frontend-php 5.0.0 alpha 2 in the Debian 9 repository? Seems that zabbix-frontend-php 5.0.0 alpha 1 cannot connect to the alpha 2 database. (message: The frontend does not match Zabbix database. Current database version (mandatory/optional): 4050035/4050035. Required mandatory version: 4050027)
  • gofree
    • Dec 2017
    • 400
    seems its there but deprecated, there are some schanges regarding php so this might be realted
    • incama
      • Jan 2015
      • 67
      Yeah, I saw that deprecated package indeed.
      apt search zabbix-frontend
      Sorting... Done
      Full Text Search... Done
      zabbix-frontend-php/unknown,now 1:5.0.0~alpha1-1+stretch all [installed]
        Zabbix network monitoring solution - PHP front-end
      zabbix-frontend-php-deprecated/unknown 1:5.0.0~alpha2-1+stretch all
      Is here a workaround so I can test alpha2?
      • incama
        • Jan 2015
        • 67
        Solved it by creating a new server running Debian 10 with Nginx which wil host the Zabbix frontend.
