Choose appropriate Zabbix Proxy DB engine
  • faramirza
    • Mar 2020
    Is there any reason not to use sqlite3 proxy? I'd think that the performance on sqlite3 would be better than using mysql server for the Zabbix 4 proxy and easier to maintain. Are there any guidelines regarding pros and cons or are they all seen as similar enough as not to matter?
    Danie
  • Hamardaban
    • May 2019
    • 2714
    I agree — for not very large systems, choosing sqlite for proxy is the right option!
    If the performance is not enough , you can always switch to a different DB.
