Is there a pre-built trigger for monitoring space free on an NFS filesystem?
  • dthacker
    • Feb 2014
    • 42
    Goal: I have several nfs filesystems that are mounted to multiple servers for transaction files or backups. I would like to set a trigger that fires when they reach < 20% free. Since one filesystem could be mounted on 20 servers, I'd just like to monitor it from a couple of individual servers, so I don't get 20 notifications.
    These are not being autodiscovered by the "Template OS Linux" template discovery rules for filesystems.
    I haven't found any examples in the manual or in the forums, and my google-fu has failed me. Does anyone have a trigger they could share?
    Thanks!
    Dave
  • BDiE8VNy
    • Apr 2010
    • 680
    Why not adding a dedicated LLD rule or triggers on these "couple" of hosts for that NFS file systems?
    • kloczek
      • Jun 2006
      • 1771
      Thanks!
      Dave
      Monitoring free space of NFS volumes should be done on NFS server because you will end up in situation when the same volume will be monitored more than one times.
