Services triggering
  • mattia.mbm
    • May 2019
    Services triggering
    i'm using zabbix since a year for now. i had it in testing and now i am deploying it for every server.
    CPU RAM and DISK monitoring is working fine with the standard windows template.
    Now i noticed that there's the services discovery but i need to "allow" the trigger for just some services (SQL,RDP,TOMCAT or similar).
    Is that possible?
  • Hamardaban
    • May 2019
    • 2714
    It's possible. Use several almost identical LLD's with different filters and a set of triggers.
    Read about the agent config option "alias”
