SNMP checks in discovery rules
  • cerasus
    • Mar 2020
    • 24
    It appears that if a discovery rule contains several SNMP checks, each one will be executed in sequence. If there's really no device on the other end, the first check will time out after 3 seconds (by default), followed by another check that will take the same amount of time and so on. So, if there's no device on the other end, it will take 3 * number of checks seconds per IP.
    Is there a way to abort all SNMP checks if nothing is listening on port 161? Maybe based on an ICMP ping against the IP?
  • Hamardaban
    • May 2019
    • 2713
    • cerasus
      • Mar 2020
      • 24
      Thank you for your reply. I don't think we're talking about the same thing though. I'm talking about reachability during network discovery. The SNMP checks against dead IPs take too long and as a result the whole discovery process is protracted unnecessarily long.
      So I'm wondering if there's a way to short circuit the defined SNMP checks in the discovery rule IF the IP doesn't respond to a ping.
      • cerasus
        • Mar 2020
        • 24
        Actually what I'm noticing is that with my Timeout configured to be 3 seconds and two discovery checks, it takes 6 seconds per check or 12 seconds per IP
        • cerasus
          • Mar 2020
          • 24
          I think I may have found the answer: https://www.zabbix.com/documentation...itemtypes/snmp
          Since Zabbix 2.2.8 and Zabbix 2.4.2 Zabbix server and proxy daemons will always retry at least one time: either through the SNMP library's retrying mechanism or through the internal bulk processing mechanism.
