Zabbix graphs PPPOE-interface users not working
  • PortalNET
    • Jan 2020
    Hi guys
    I have an issue with zabbix monitoring graphs statistics for users using PPPOE-interface in our PPPOE-Server, first time user connects on PPPOE-SERVER zabbix monitors graphs correctly, after user reboots connection from PPPOE-server it stops monitoring graphs, it looks like OIDs change every time the pppoe-client reboots on the pppoe-server, because he obtains a new pppoe ip also.
    is there a way to fix this? either refresh rate to refresh pppoe-interface OID automatically or put the OID to a static format ?
    all the other static graphs such as Link bandwidth interface, and all other static interfaces i can monitor graphs correctly, its just the PPPOE instances that are giving me troubles.
  • dave02
    • May 2020
    Hello friend, the same thing happens to me.
    did you solve your problem ?
    • Mike2K
      • Oct 2018
      • 60
      If the OID's change, you could do an LLD to discover all interfaces.
      Be sure the set the "Keep undiscovered items" to 0 and set the discovery rule to run every few minutes so new interfaces are quickly discovered.
