Interface eth1(): Ethernet has changed to lower speed than it was before
  • julio.tkac
    • Jan 2020
    I have an Endian firewall, monitored by SNMP on Zabbix.
    The eth1 (Gigabit) interface, was connected to a switch, to a Gigabit port.
    But recently, it was switched to a 100mbps port on the same switch.
    Now Zabbix constantly displays this message: "Interface eth1(): Ethernet has changed to lower speed than it was before"
    and I want to adjust it so that you understand that now the speed is 100mbps.
    Trigger: Interface eth1(): Ethernet has changed to lower speed than it was before
    Problem expression:
    {Endian Firewall:net.if.speed[ifHighSpeed.3].change()}<0 and {Endian Firewall:net.if.speed[ifHighSpeed.3].last()}>0 and ( {Endian Firewall:net.if.type[ifType.3].last()}=6 or {Endian Firewall:net.if.type[ifType.3].last()}=7 or {Endian Firewall:net.if.type[ifType.3].last()}=11 or
    {Endian Firewall:net.if.type[ifType.3].last()}=62 or {Endian Firewall:net.if.type[ifType.3].last()}=69 or {Endian Firewall:net.if.type[ifType.3].last()}=117 ) and ({Endian Firewall:net.if.status[ifOperStatus.3].last()}<>2)
    Recovery expression:
    ({Endian Firewall:net.if.speed[ifHighSpeed.3].change()}>0 and {Endian Firewall:net.if.speed[ifHighSpeed.3].prev()}>0) or ({Endian Firewall:net.if.status[ifOperStatus.3].last()}=2)
    I didn't understand the logic and I don't know how to correct it.
    Zabbix 4.0.0alpha7 // Endian Firewall Community release 3.2.5
  • Noobz
    • Jun 2020
    • 105
    Look at the recovery expression - you can either disable and reenable the port, change it to 10Mb and back to 100Mb - or do what we did and change the recovery expression to none and only allow manual close.
