How I can updating Zabbix1.0 to Zabbix.1.1 ?
  • bigJoe
    • Dec 2005
    Hi you all,
    I've installed zabbix1.0 on hp-ux os and now I want make the update to 1.1 version.
    How I can make this updating ?
    Thanks to all .
  • forlinuxsupport
    • Oct 2005
    • 39
    Hi
    I want to do the same. any ideas ?
    Is it a case of installing the new zabbix and telling it to use the old zabbix database ?
    is there a document with the update steps in it ?
    Cheers
    Andy
    • James Wells
      • Jun 2005
      • 664
      Greetings,
      Unfortunately, it is not quite that simple. To perform the update, you will need to perform the database upgrades manually, then you can drop the new zabbix_server into place. Before you fire up the zabbix_server, you will need to go through the UI and ensure that your items are using the updated keys. Most of the old Zabbix-1.0 keys will continue to work, but they have been deprecated and may be removed in future releases. Having said that, however, there are some item keys which have already been removed.
      Unofficial Zabbix Developer
      • forlinuxsupport
        • Oct 2005
        • 39
        Hmm so its not a quick and easy process.
        I wil ltake a look.. thanks for the help
        • tvigneron
          • Sep 2006
          • 12
          Hi everybody!
          I'd like to update from zabbix 1.0 to 1.1.2 too, it seems to be not very easy...
          Anybody try to change the database manually? What's the result?
          I want to keep all my datas, templates and graphs from previous version, it's possible or not?
          If someone update successfully zabbix, please tell us how to do!
          thanks!!!
          • forlinuxsupport
            • Oct 2005
            • 39
            Hi
            yip thats what Im after too..
            Keep all old data and servers etc.. but use new version
            cheers
            andy
            • tvigneron
              • Sep 2006
              • 12
              Where can I find a DB upgrade patch for zabbix 1.0 to 1.1.2?
              I can't see it in the zabbix-1.1.2 package (/upgrades/dbpatch/)?
              Thanks for your help!
