Zabbix CURL_OPENSSL_3
  • Zab_Des
    • Mar 2020
    I'm upgrading my zabbix-server. Everytime i try to remove everything and reinstall or upgrade the zabbix server I get an error message:
Name:	zabbix image.png
    When i try installing the curl_openssl_3 package, it works but it downgrades my zabbix server back to version 3.4.
    Any help?
  • tim.mooney
    • Dec 2012
    • 1436
    You don't provide any information on
    • what operating system and version your Zabbix server is running
    • what the version of Zabbix you're trying to upgrade to is
    • whether you're using packages from your OS vendor or from zabbix.com
    so without that information, the best guess I can make is that you're trying to upgrade using packages that were built for (and only support) a newer version of the operating system than the one you're running.
