Problems trigger text isint updated to match new trigger description
  • drenriza
    • May 2019
    • 19
    Hi all!
    I have updated some of my triggers through my templates.
    In my 'Problems' overview though, the new trigger text isint shown and instead the old trigger text is shown.
    If i click the problem and go to 'configuration' i can see the new trigger text and expression
    Example
    1. Created a trigger called 'Trigger 1'
    2. Trigger 1 triggers in problems, for example C: < 15GB
    3. I update Trigger 1 to be called 'Trigger C: problem'
    4. In my problems overview my problem text is still the old trigger description 'Trigger 1' instead of 'C: < 15GB'
    How can i fix this problem?
    Thanks in advance.
    Best regards
  • tim.mooney
    • Dec 2012
    • 1430
    Re-apply the template to the host(s)
    • Semiadmin
      • Oct 2014
      • 1626
      In Zabbix 4.* this is behavior "by design". Changes in triggers don't affect current and past problems. The only exception - deletion of a trigger.
