Zabbix Client Repo 3.5 Unavailable
  • afagund
    • Feb 2018
    • 10
    Does anyone know what happened to the 3.5 REPO? I am trying to install the client from the URL below, but it shows 404 - Not found.
  • tim.mooney
    • Dec 2012
    • 1436
    Scrolling through the release notes page on www.zabbix.com, I don't see release notes for 3.5. I'm not aware of that ever having been a released, supported version. You probably want to consider looking at the 4.0 series, which is a Long Term Support (LTS) series too.
    • Atsushi
      • Aug 2013
      • 2028
      What was in the 3.5 directory is not an official release version of the software. It is a trial version before the release of 4.0 and is under development. Do not use it in a production environment. The current 4.5 directory is a similar underdeveloped version and should not be used in a production environment.
      If you want to use 4.0, the official version has been released in the 4.0 directory, so please delete the version obtained from the 3.5 directory and reinstall it.
