disk (re)discovery
  • xanadu
    • Sep 2014
    • 62
    disk (re)discovery
    After creating a new virtual machine and you add that client host to Zabbix you have the current state of that virtual machine monitored.
    However the life of a virtual machine changes frequently.
    In many cases disks are added or removed.
    Is there a way to do a virtual machine (re)discovery of all disks used on that particular virtual machine? The VM's are mainly Windows hosts.
    How can it be done? I could not find it in the support section nor on the forums.
  • LenR
    • Sep 2009
    • 1011
    LLD runs at the frequency specified in the rules. If it's hourly, new disks that pass any filtering rules, will be added within an hour. Disks that go away will be kept for the value specified in "Keep lost resources period".
    I add a "is it mounted" test to disks, so of course, I get a trigger if disks go away.
