Zabbix - host connection rejected, different subnet, two routers
  • rybanapet
    • Mar 2020
    Good evening,
    I have a problem with Zabbix hosts on different subnet. I have Zabbix server: 192.168.51.22, subnet 51.0/24. Hosts on this subnet working normally, but when I try to add host on different subnet, for example 192.168.1.225/20 (Windows Server) it is not working. ZBX icon is red with "Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer.
    Zabbix agent log: failed to accept an incoming connection: connection from "10.10.10.6" rejected, allowed hosts: "192.168.51.222"
    But IP 10.10.10.6 is used to connect Router A and Router B (10.10.10.4/30 network)
    Zbx server 51.222 -> Router A 10.10.10.6 -> Router B 10.10.10.5 -> 192.168.1.225 (Win Server)
    I hope it is understandable.
    Thank you for your help!
  • tim.mooney
    • Dec 2012
    • 1430
    "Router A" (or perhaps "Router B") is doing something much more than just routing packets. Are you sure it's not doing NAT or something else, for connections? One of them seems to be rewriting TCP packets.
    • rybanapet
      • Mar 2020
      YES! It was wrong configuration with SRCNAT. Thank you !!
