hello
I'm using Zabbix 2.4, I have some desktop to the client (check active and Low-level discovery) fails to submit the values of the items to the server, communication with the server is because:
- The client recover that items must monitor
- The server automatically creates the host and make some items (not all) but does not show values in them.
- In the client log, I can see that makes sending (see 'JSON before sending') but then a 'JSON back [{"response": "success", "info", "processed: 0; failed: 15 ; total: 15; seconds spent: 0.000273 "}] '
- In the log of the server I manage not see anything associated with the client.
Do not know what else to look .. where should look to find the error?
(Sorry for using translate)
The client log:
Thanks for lleer up down here.
The client log:
28502:20141126:082605.780 collector [idle 1 sec]
28506:20141126:082606.712 In send_buffer() host:'zabbix.mydom.com.ar' port:10051 values:15/100
28506:20141126:082606.712 Will not send now. Now 1417001166 lastsent 1417001047 < 120
28506:20141126:082606.712 End of send_buffer():SUCCEED
transcends time and try to send 15/100...
28506:20141126:082607.716 In send_buffer() host:'zabbix.mydom.com.ar' port:10051 values:15/100
28506:20141126:082607.716 JSON before sending [{"request":"agent data","data":[{"host":"Tes02","key":"agent.ping","value":"1","clock":1417001053,"ns":252962000
},{"host":"Tes02","key":"MemBuffersCacheFree","value":"766820352","clock":1417001054,"ns":261809000},{"host":"Tes02","key":"net.if.discovery","value":"{\"data\"
:[{\"{#IFNAME}\":\"lo\"},{\"{#IFNAME}\":\"eth7\"},{\"{#IFNAME}\":\"sit0\"}]}","clock":1417001054,"ns":262110000},{"host":"Tes02","key":"system.cpu.load[,avg15]"
,"value":"0.070000","clock":1417001054,"ns":262383000},{"host":"Tes02","key":"system.cpu.load[,avg1]","value":"0.070000","clock":1417001054,"ns":262645000},{"ho
st":"Tes02","key":"system.cpu.load[,avg5]","value":"0.120000","clock":1417001054,"ns":262905000},{"host":"Tes02","key":"system.cpu.util[,idle,avg1]","value":"97
.111794","clock":1417001054,"ns":263157000},{"host":"Tes02","key":"system.cpu.util[,iowait,avg1]","value":"0.390074","clock":1417001054,"ns":263402000},{"host":
"Tes02","key":"system.cpu.util[,system,avg1]","value":"0.755249","clock":1417001054,"ns":263645000},{"host":"Tes02","key":"system.cpu.util[,user,avg1]","value":
"1.701386","clock":1417001054,"ns":263916000},{"host":"Tes02","key":"system.swap.size[,free]","value":"2154876928","clock":1417001054,"ns":264161000},{"host":"T
es02","key":"vm.memory.size[cached]","value":"702373888","clock":1417001054,"ns":264456000},{"host":"Tes02","key":"vm.memory.size[free]","value":"26791936","clo
ck":1417001054,"ns":264696000},{"host":"Tes02","key":"vm.memory.size[shared]","value":"Supported for Linux 2.4 only.","state":1,"clock":1417001054,"ns":26493500
0},{"host":"Tes02","key":"net.if.discovery","value":"{\"data\":[{\"{#IFNAME}\":\"lo\"},{\"{#IFNAME}\":\"eth7\"},{\"{#IFNAME}\":\"sit0\"}]}","clock":1417001114,"
ns":504718000}],"clock":1417001167,"ns":716458000}]
sending fails ...
28506:20141126:082607.717 JSON back [{"response":"success","info":"processed: 0; failed: 15; total: 15; seconds spent: 0.000273"}]
28506:20141126:082607.717 In check_response() response:'{"response":"success","info":"processed: 0; failed: 15; total: 15; seconds spent: 0.000273"}'
28506:20141126:082607.717 info from server: 'processed: 0; failed: 15; total: 15; seconds spent: 0.000273'
28506:20141126:082607.717 End of check_response():SUCCEED
28506:20141126:082607.717 OK
28506:20141126:082607.717 End of send_buffer():SUCCEED
28502:20141126:082612.808 collector [idle 1 sec]
28506:20141126:082613.740 In send_buffer() host:'zabbix.mydom.com.ar' port:10051 values:0/100
28506:20141126:082613.740 End of send_buffer():SUCCEED
28506:20141126:082613.740 active checks #1 [getting list of active checks]
28506:20141126:082613.740 In refresh_active_checks() host:'zabbix.mydom.com.ar' port:10051
28506:20141126:082613.740 sending [{"request":"active checks","host":"Tes02","host_metadata":"Linux 0dea3e988cf1da296aeb47c29280b9b8"}]
28506:20141126:082613.740 before read
28506:20141126:082613.742 got [{"response":"success","data":[{"key":"agent.ping","delay":120,"lastlogsize":0,"mtime":0},{"key":"agent.version","delay":1800,"la
stlogsize":0,"mtime":0},{"key":"mediaPermisosOK","delay":86400,"lastlogsize":0,"mtime":0},{"key":"MemBuffersCacheFree","delay":120,"lastlogsize":0,"mtime":0},{"
key":"net.if.discovery","delay":60,"lastlogsize":0,"mtime":0},{"key":"net.tcp.service[ssh,,22]","key_orig":"net.tcp.service[ssh,,{$SSHPORT}]","delay":7200,"last
logsize":0,"mtime":0},{"key":"proc.num[ntpd]","delay":18000,"lastlogsize":0,"mtime":0},{"key":"proc.num[zabbix_agentd]","delay":3600,"lastlogsize":0,"mtime":0},
{"key":"system.boottime","delay":300,"lastlogsize":0,"mtime":0},{"key":"system.cpu.load[,avg15]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.cpu.load[
,avg1]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.cpu.load[,avg5]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.cpu.num","delay":25920,"las
tlogsize":0,"mtime":0},{"key":"system.cpu.util[,idle,avg1]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.cpu.util[,iowait,avg1]","delay":120,"lastlogsi
ze":0,"mtime":0},{"key":"system.cpu.util[,system,avg1]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.cpu.util[,user,avg1]","delay":120,"lastlogsize":0,
"mtime":0},{"key":"system.hostname","delay":18001,"lastlogsize":0,"mtime":0},{"key":"system.localtime","delay":21600,"lastlogsize":0,"mtime":0},{"key":"system.s
wap.size[,free]","delay":120,"lastlogsize":0,"mtime":0},{"key":"system.swap.size[,total]","delay":43200,"lastlogsize":0,"mtime":0},{"key":"system.uname","delay"
:18001,"lastlogsize":0,"mtime":0},{"key":"system.uptime","delay":300,"lastlogsize":0,"mtime":0},{"key":"vfs.fs.discovery","delay":86400,"lastlogsize":0,"mtime":
0},{"key":"vm.memory.size[cached]","delay":120,"lastlogsize":0,"mtime":0},{"key":"vm.memory.size[free]","delay":120,"lastlogsize":0,"mtime":0},{"key":"vm.memory
.size[shared]","delay":120,"lastlogsize":0,"mtime":0},{"key":"vm.memory.size[total]","delay":43200,"lastlogsize":0,"mtime":0}]}]
28506:20141126:082613.742 In parse_list_of_checks()
28506:20141126:082613.742 In disable_all_metrics()
28506:20141126:082613.742 In add_check() key:'agent.ping' refresh:120 lastlogsize:0 mtime:0
28506:20141126:082613.742 End of add_check()
28506:20141126:082613.742 In add_check() key:'agent.version' refresh:1800 lastlogsize:0 mtime:0
28502:20141126:082715.056 collector [idle 1 sec]
28506:20141126:082716.000 In send_buffer() host:'zabbix.mydom.com.ar' port:10051 values:17/100
28506:20141126:082716.000 Will not send now. Now 1417001236 lastsent 1417001167 < 120
28506:20141126:082716.000 End of send_buffer():SUCCEED
28506:20141126:082716.000 active checks #1 [idle 1 sec]
