Item type: Database Monitor
There seems to be no way to `SET ANSI_WARNINGS ON` and `SET ANSI_NULLS ON` in the query section to disable the error. At least isn't working. Is there any other way to set it?
Item Error: Heterogeneous queries require the ANSI_NULLS and ANSI_WARNINGS options to be set for the connection.
I tried
before the select statement and it did not work. I also tried [CODE}GO SET ANSI_WARNINGS ON; ANSI_NULLS ON; select * ... GO[/CODE] but that did not work either - zabbix reported syntax error.
Any suggestions on how to resolve this?
Here is my Query:
I tried
SET ANSI_WARNINGS ON; SET ANSI_NULLS ON; select * ...
Here is my Query:
select sum(item_count) from (select
coalesce(c.cnt, 0) as [item_count]
from LINKED_DB_USER.[UserDB].[dbo].[User] as us LEFT JOIN LINKED_DB_USER.[USerDB].[dbo].[Account] as cs ON us.[user_id] = cs.[user_id]
FULL OUTER JOIN
select [Account_ID], count(*) as cnt
from [OnlineUSers].[dbo].[USER_NAME] where USER_ID in (select USER_ID from [OnlineUsers].[dbo].[Last_Login])
group by [Account_ID]
) c on c.[Account_ID] = us.[Unique_ID] where cs.name = 'SOME_NAME') src;
