{HOST.IP1} in Maps
  • vendelin
    • Mar 2020
    {HOST.IP1} in Maps
    Hello
    i would like to use {HOST.IP1} and {HOST.IP2} for show more IP adress on host in Maps.( Our windows server have 3 Networks). But, now is working only {HOST.IP} (i see IP adress) and {HOST.IP1} etc not.
    Can you help me, how i can show more then one IP adress?
    Thank you
    Vaclav
  • vendelin
    • Mar 2020
    nobody with same problem?
    • tim.mooney
      • Dec 2012
      • 1436
      How many interfaces (e.g. Zabbix agent, SNMP, etc.) do you have defined for the host in Zabbix?
      {HOST.IP1} and {HOST.IP2} correspond to each host interface you've defined for the host in the Zabbix config. If you have 3 NICs in a host but you've only defined one interface within Zabbix, you'll only see the IP for the interface that you have defined in Zabbix.
