Zabbix server for PowerPC
  • guille_pm
    • Mar 2020
    • 16
    Hi! I'm new to Zabbix (and Linux for that matter) so please excuse me if I say something that's accurate or correct.
    I have a full PowerPC environment (mostly running IBM i and a couple of AIX, plus VIOS). I was following Zabbix's installation instructions (on a CentOS 7 partition on a Power9 server), but it seems there's no RPM files for ppc, or at least not on the repository the instructions say (rpm -Uvh https://repo.zabbix.com/zabbix/4.4/r...el7.noarch.rpm). Is Zabbix server available for installation on PowerPC? Thanks!
  • tim.mooney
    • Dec 2012
    • 1430
    It doesn't appear so, but Zabbix is open source, so if you're comfortable compiling software you could build your own binaries for your platform.
    • guille_pm
      • Mar 2020
      • 16
      Thanks! I'm kinda new to Linux too, but I'll give it a try. Thanks again!
      • guille_pm
        • Mar 2020
        • 16
        So, just for records, I got it to work. Here's my setup
        Power9 hardware (ppc64le)
        Centos 7
        Zabbix 4.4.7 installed from sources
        • dave_t
          • Apr 2007
          • 28
