Calculate Total Bandwidth
  • kanour
    • May 2006
    • 105
    Hi.
    I have trying to search a solution to this, but several posts are too old or dont really understand them.
    I would like to be able to see how much we downloaded/uploaded per day, week, month, etc.
    I am using SNMP to get the following:
    key: ifInOctets[bge0]
    SNMP OID: IF-MIB::ifInOctets.1
    But I am getting the actual value on the interface. So if the value is reset on the interface we can start over.
    If I set Delta (simple change) I get the value per update interval, but the values are not add up.
    Please would you be able to point me into correct direction?
    Thank you.
