Low Level discovery and cdrom
  • HeadQuaker
    • Jul 2015
    • 58
    I have set a LLD for hard drive.
    It is working, a bit too much because i can see cdrom/dvdrom too;
    How can I avoid this ?
    Useing Filter ? What should i set?
    thank you
    SOLVED : the issue was just the delay of applying the template modification to all hosts... So dumb
  • HeadQuaker
    • Jul 2015
    • 58
    Already seen that but it does not working, probably i'm doing it bad.
    It is in windows environment
    • HeadQuaker
      • Jul 2015
      • 58
      Any idea ?
      What i have set :
      {#FSDRIVETYPE} not match cdrom
      • Hamardaban
        • May 2019
        • 2714
        Show which key you use for LLD and which json it returns for some host with a cdrom.
        • HeadQuaker
          • Jul 2015
          • 58
          My LLD is like that :
          Zabbix Agent, key : vfs.fs.discovery
          How can i see the json ?
          zabbix get agent ?
          Thx for ur help
          • Hamardaban
            Hamardaban commented
            At zabbix server- zabbix_get -s IP_OF_HOST -k "vfs.fs.discovery"
        • HeadQuaker
          • Jul 2015
          • 58
          it seems good :
          [{"{#FSNAME}":"C:","{#FSTYPE}":"NTFS","{#FSDRIVE TYP E}":"fixed"},{"{#FSNAME}":"D:","{#FSTYPE}":"UDF" ," {#FSDRIVETYPE}":"cdrom"}]
          but not working... hum
          • Hamardaban
            • May 2019
            • 2714
            That's all right. Show how the filter is configured (picture)?
            • HeadQuaker
              • Jul 2015
              • 58
              It seems working now... Maybe it was the delay of applying the modification on template to hosts.
              Thanks for your help, I've learn how to see json from servers
              • Hamardaban
                That's good! For information, there is a timeout for the zabbix server to apply the saved configuration.
            • HeadQuaker
              • Jul 2015
              • 58
              Yes but it takes a really long time the check is every 1H, that's why i found it strange.
                Filtering is described in
                Even examples are for filesystem discovery.
