fping question
  • DonPook
    • Dec 2019
    • 38
    fping question
    I want to use pings to check the availability of multiple servers I monitor using a proxy. Now, I have installed fping on my proxy server and also on my application server (Not sure if it works correct, permission wise on app server). I have still not tested whether it works or not (will do tomorrow), I have some questions:
    1) Does fping need to be installed on both app and proxy server? I guess only on proxy but want to be sure.
    2) If I do not need it on app server, how do I clean this message from App servers logs, and why do I see it? (At least one of '/usr/sbin/fping', '/usr/sbin/fping6' must exist. Both are missing in the system.)
    (I have deleted the fpinglocation=..., since I realised I probably don't need it)
    Kind Regards
