Hello!
The simplest way to get rid of those triggers is just to disable them on selected hosts if you really don't need them. But I'd suggest to understand why they appear and fix those problems.
It's not about ack. Open Configuration->Hosts, open hosts triggers and just click Enabled on the right in the Status column. It will disable selected trigger on the host. It won't bother you anymore. But be sure you really don't need that trigger on that specific host.
