Querying a MSSQL 2016 counter
  • ath_vc
    • Apr 2020
    Hi I am trying to query a MSSQL 2016 counter
    HTML Code:
    Get-Counter -ListSet 'MSSQL$MSSQLSERVER:SQL Statistics' | Select-Object -ExpandProperty Counter
    \MSSQL$MSSQLSERVER:SQL Statistics\Batch Requests/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Forced Parameterizations/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Auto-Param Attempts/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Failed Auto-Params/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Safe Auto-Params/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Unsafe Auto-Params/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\SQL Compilations/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\SQL Re-Compilations/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\SQL Attention rate
    \MSSQL$MSSQLSERVER:SQL Statistics\Guided plan executions/sec
    \MSSQL$MSSQLSERVER:SQL Statistics\Misguided plan executions/sec
    HTML Code:
    zabbix_get -s mssqlserver.example.com -k perf_counter["\MSSQL$MSSQLSERVER:SQL Statistics\Batch Requests/sec"]
    ZBX_NOTSUPPORTED: Cannot obtain performance information from collector
    Is the syntax I am using Wrong ?
    Best Regards,
    A
  • ath_vc
    • Apr 2020
    I figured it out, Please close the issue
