Better guide?
  • sunadmn
    • Aug 2006
    • 38
    Better guide?
    Does anyone know if there is a more in depth guide for configuring a triggers,hosts,templates, groups, graphs, maps, etc. under the Zabbix system. The reason I ask is the tutorials are fine to get you just up and runnign but I really want to set this up to do some nitty gritty in my farms and searching through the forums is a bit messy so I was wondering if their was an advanced guide to the system with more detail and greater examples.
    Thanks all
    -Stephen
  • erisan500
    • Aug 2005
    • 285
    could you give a few examples of what kind of exotic stuff you want to do?
    Greetings
    EriSan
    • sunadmn
      • Aug 2006
      • 38
      Well nothing too exotic by far but just looking for deeper explanations of triggers how to make a custom one how dependencies work things of this nature. I very well may not be getting what I need from the documents and just require a higher overview. If it makes any difference I am attempting to migrate from a BigSister system currently so things are quite a bit different in how.why things work so my learning curve is a bit biased due to working with BS for so long. Right now what I want to do is have my server farms (4) grouped together and when a user logs into the system have a brief overview of what's going on with each group of farms. I would prefer a look that like the way BS & BB display the main landing page where I have the farms then have what's wrong. I think this should be done via a template? Is that correct?
      Thanks,
      -Stephen
      • erisan500
        • Aug 2005
        • 285
        indeed, templates and maps is what you are looking for.
        BTW, can you post screenshots of this:
        Greetings
        EriSan
