Trigger if last X values in a row are equal to "1"
  • jorioux
    • Nov 2011
    • 10
    What would be the trigger expression for this:
    "Expression is true if the last 5 values in a row of an item is equal to 1."
  • slydog
    • Oct 2014
    • 16
    Are you trying to track the value of a single Item over a span of time?
    If so, and say you wanted to know it over 5 minutes; then instead of:
    {.....last(0)}=1
    you would use
    {.....last(,5m)}=1
    If that is not what you are trying to do, then you need ask a more detailed question in order to get help.
    • jan.garaj
      • Jan 2010
      • 506
      Simple math:
      {item.last(#1)} = 1 and {item.last(#2)} = 1 and {item.last(#3)} = 1 and {item.last(#4)] = 1 and {item.last(#5)} = 1
      or be smart:
      {item.last(#1)} = 1 and {item.max(#5)}=1 and {item.min(#5)}=1
      or be smart^2:
      {item.last(#1)} = 1 and {item.delta(#5)}=0
      General trigger if last X values in a row are equal to Y
      {item.last(#1)} = Y and {item.delta(#X)}=0
