Processing json values who are linked to unix time
  • RadicalEd
    • Nov 2017
    • 16
    I hope that someone is able to help me with this problem as I wasn't able to come up with a solution for this "unique" system that I'm trying to monitor. The system is a storage which I'm able to query via RestAPI. When it's about the performance values, the system is not able to provide me with a "now" value at the time of the query. Instead it's giving me a history of the last minutes with a unix time. The json response looks like this:
        "datapoints": [
            2370.4999999999995,
            1586459100
            2388.599999999999,
            1586459160
            2369.5000000000005,
            1586459220
            2609.799999999996,
            1586459280
            1626.299999999999,
            1586459340
            1317.3999999999985,
            1586459400
        "target": "stats.counters.scvmclient.allhosts.nfsReads.cluster.rate"
    Another problem is that the last value is sometimes "null" when the system wasn't able to create it yet.
    The question is if I can somehow use these values with an exact time to "inject" it into the zabbix data history? Another option would be if I would simply be able to use the last option and work around the "null" problem. But I didn't found a way how I could use the last value in this json data schema.
    Hope someone is able to give me a hint how I can approach this problem
    Happy eastern!
