Zabbix Proxy installation from Packagies
  • nabberuk
    • May 2010
    • 82
    I've just attempted to install zabbix proxy (MySQL) from the Ubuntu repository as per https://www.zabbix.com/documentation..._from_packages
    Trouble is it doesn't look like its configured or even created the MySQL database. What should I do? How come it hasn't created it?
    EDIT:
    Looks like the database hasn't been created.
    2316:20141208:121833.405 [Z3001] connection to database 'zabbix_proxy' failed: [1049] Unknown database 'zabbix_proxy'
    2316:20141208:121833.405 Cannot connect to the database. Exiting...
  • Alberto Freire
    • Jul 2014
    • 24
    Send the result this command:
    # mysql -u root -p -e "show databases;"
    and this:
    # grep -v "^#" /pathzabbixconf/zabbix_proxy.conf | sed '/^$/d'
    Cheers!
    • nabberuk
      • May 2010
      • 82
      I have the following databases;
      information_schema
      MySQL
      performance_schema
      zabbix_proxy
      and the next command outputs the following (edited);
      Server=monitor.domain.com
      ServerPort=10051
      Hostname=KIB_Proxy
      LogFile=/var/log/zabbix-proxy/zabbix_proxy.log
      PidFile=/var/run/zabbix/zabbix_proxy.pid
      DBHost=localhost
      DBName=zabbix_proxy
      DBUser=root
      DBPassword=edited
      FpingLocation=/usr/bin/fping
      Fping6Location=/usr/bin/fping6
      I've managed to connect to the zabbix_proxy database via workbench and import the data. after checking the logs it still gives the above error saying unknown database.
      • nabberuk
        • May 2010
        • 82
        When installing from a package, should it install the database and schema by default as I have a few proxies to setup and don't want to mess about each time I install one.
        • Alberto Freire
          • Jul 2014
          • 24
          Well, I guess that a package or installation were corrupted. Try as root, to remove and re-install the Proxy, but remember of delete the database proxy_zabbix.
          Ps: My installations are created DB called 'zabbix' and not 'zabbix_proxy', same thing to user.
          Good luck.
          • nabberuk
            • May 2010
            • 82
            Good luck.
            I may have created the zabbix_proxy database. I'm doing a clean install now of the OS. Do I need to do anything other than install zabbix-proxy-MySQL?
            I'm guessing it will auto install/configure the db?
            • Alberto Freire
              • Jul 2014
              • 24
              In my zabbix servers (ubuntu), I install these packages:
              build-essential mysql-server libmysqlclient15-dev php5 php5-gd php5-mysql snmp libsnmp-dev snmpd libcurl4-openssl-dev fping
              After, follow the manual: https://www.zabbix.com/documentation..._from_packages
              Cheers!
              • nabberuk
                • May 2010
                • 82
                Cheers!
                how come you install build-essential etc, thought that was for if you were building from source?
                Oh and is this for the zabbix proxy and not zabbix
                • Alberto Freire
                  • Jul 2014
                  • 24
                  Hmm... I don't know! I never install the Zabbix* from apt-get, yum...
                  But don't cost try to install theses packages...
                  Cheers!
