ICMP Ping = 0 for 60 minutes => Trigger
  • c1support
    • Apr 2020
    • 47
    Hi there
    I am still new to Zabbix (great tool btw), and I am still a bit struggling with syntax.
    What I would like to do is generating a trigger when a host is unresponsive for a loger period of time.
    Zabbix Server 4.4.7
    Target system has no client; SSH access is not allowed
    I have been successfully using "Template Module ICMP Ping" with the syntax
    {targetSystem:icmpping.max(#3)}=0
    This generates a trigger after three unsuccessful pings with severity "High").
    Now, I would like to do more less the same, but only generating a trigger after the target system has been unresponsive for say 60 minutes.
    I imagine something like
    {targetSystem:icmpping.max(#3).average(60m)}=0
    However, this raises the error "Cannot add trigger: incorrect trigger expresseion" (which I kind of expected).
    After some bad experiences with Zabbix Scripts where I forgot to limit the number of pings, I am a bit hesitant trying
    {targetSystem:icmpping.avg(60m)}=0
    {targetSystem:icmpping.count(60m)}=0
    => Is this even possible with simple checks (https://www.zabbix.com/documentation.../simple_checks)?
    => If not, would it be possible to use Actions and Escalation (https://www.zabbix.com/documentation...on/escalations)?
    => Or is there a better suited concept?
    Note: in the end of the day, it is important that the result is a normal trigger (because I do some alarming using Zabbix API, which in turn relies upon triggers).
  • Semiadmin
    • Oct 2014
    • 1625
    {targetSystem:icmpping.max(60m)}=0
    but {targetSystem:icmpping.avg(60m)}=0 is the same
    or {targetSystem:icmpping.count(60m,1)}=0
    • c1support
      • Apr 2020
      • 47
      Thank you very much for the fast reply!
      Seems to work with shorter durations (I only tried "max(4m)"), currently testing "max(60m)".
