Innodb_data_file_path for zabbix
  • GeorgeKup
    • Nov 2019
    • 98
    Do not tell me if setting this parameter to MySQL performance can be of any value:
    innodb_data_file_path
    on the Internet describe different meanings:
    innodb_data_file_path = ibdata1: 128M; ibdata2: 128M: autoextend: max: 4096M
    innodb_data_file_path = ibdata1: 1G
    innodb_data_file_path = ibdata1: 10M: autoextend
    innodb_data_file_path = / data / ibdata1: 2000M; / data / ibdata2: 2000M / data / ibdata3: 100M: autoextend: max: 2000M
    Does it make any sense if the innodb_file_per_table = 1 parameter is set at the same time to set the innodb_data_file_path parameter?
  • tim.mooney
    • Dec 2012
    • 1436
    This question really is about MySQL and/or MariaDB, not Zabbix. I think you might get better results if you ask the question on the MySQL or Percona forums.
