Hello. Beginner here. I'm using the 4.4.6 VHD appliance on Hyper-V. I have my server up and monitoring several of my hobby boxes successfully, good fun!
I'm now trying to enable HTTPS for my Zabbix server's Monitoring page. I'm using an internal CA (pfSense generated) and have created the cert/key. I could not figure out how to upload them to the server, so I created 2 txt files (zabbix.key and zabbix.crt, chmod 777) in the /etc/ssl/apache2 folder and copied the relevant text from the cert files, no leading or trailing spaces. Edited the zabbix_server.conf to point to the certs(SSLCertLocation, SSLKeyLocation), restarted apache, restarted the server, no benefit. I've Googled about all I can about adding it to apache, but nothing seems to work. I installed ufw so I could see what ports are opened (status below). I have tried to telnet to the server on 443 without success. I had also tried to use LetsEncrypt from a video I saw on YouTube, but was unable to complete because I only have a workgroup, not a domain. Can someone point me in the right direction before I muck things up completely? I'm sure it's a lot simpler than I'm making it out to be! Thanks for reading and any feedback.
EDIT Finally got it, but I don't know I could do it again. Good thing I don't get paid by the job!
HTML Code:
UFW Status: active Logging: on (low) Default: deny (incoming), allow (outgoing), disabled (routed) New profiles: skip To Action From -- ------ ---- 80 ALLOW IN Anywhere 443 ALLOW IN Anywhere 22 ALLOW IN Anywhere 10050 ALLOW IN Anywhere 10051 ALLOW IN Anywhere 80 (v6) ALLOW IN Anywhere (v6) 443 (v6) ALLOW IN Anywhere (v6) 22 (v6) ALLOW IN Anywhere (v6) 10050 (v6) ALLOW IN Anywhere (v6) 10051 (v6) ALLOW IN Anywhere (v6)
