Using Zabbix v4.47 (will be upgrading as soon as v5.0 is available), I would like to display the currently pending problems on a Dashboard with a widget.
I currently use "Problems by severity" with the following parameters:
- Show: Total
- Layout: Vertical
- Show perational data: none
- Problem display: All
This almost does what I have in mind, except that it is a bit too colorful:
Better would be that the color for the severity is only displayed when there actually is at least one pending problem of said severity. All lines/severities with no pending problems should be in a discrete color (e.g. grey):
=> Is there an easy possibility (i.e. without source modification) to achieve this?
=> If not, would this be of more general interes to place a change request at https://support.zabbix.com/projects/ZBXNEXT?
- Show: Total
- Layout: Vertical
| 0 Disaster |
| 0 High |
| 0 Average |
| 1 Warning |
| 1 Information |
| 0 Not classified |
| 0 Disaster |
| 0 High |
| 0 Average |
| 1 Warning |
| 1 Information |
| 0 Not classified |
