How to get bytes traffic incoming instead of speed
  • josefco_ap
    • Apr 2020
    Hi all, I'm trying to do a calculated item with the data that I collected from the Template "Template OS Linux by Zabbix Agent"
    The original item has preprocessing to translate the data into bps.
    I want to give this data and calculate the current bytes received during the 3 minutes slot between updates.
    I make some trials but the data I calculated in the new item seems not accurate.
    How con I setup it properly? some suggestions?
  • josefco_ap
    • Apr 2020
    I finally get it working, thanks btw!
