Trigger when value is unchanged for 15 minutes
  • moddeydhoo
    • Apr 2020
    Hi guys,
    As the title suggests, I'm trying to create a trigger for a value that has remained unchanged for a period of time. Normal behavior for this value is to fluctuate up/down throughout the course of the day, thus 15 minutes of no change would be a cause for concern.
    To no avail, I have searched for similar questions and bastardized my own expressions using the triggers documentation... queue the "I'm fairly new to..." line
    Thank you in advance.
  • tim.mooney
    • Dec 2012
    • 1437
    My first thought was to use a calculated item based on something like max - min, but I actually don't think that's needed, since the trigger functions include a delta() function that appears to do exactly what you need. If the .delta(15m) == 0 (for integer item values) then your item hasn't changed in 15 minutes.
    If your item is returning floating point values, you probably can't look for a delta of 0, since there might be very slight differences in the floats, so you would use .delta(15m) < some_small_float_number_here
    • moddeydhoo
      • Apr 2020
      Tim, Thank you very much, the delta function has worked a treat!
