I've had events and triggers go off, but just minutes later they vanish from the web interface.
e.g.: a machine has low memory, a trigger goes off and sends a message. It is resolved, and an hour later when I have time to investigate I check zabbix web interface for the problem.
Monitoring > Dashboard > Last 20 issues says "No events found"
Monitoring > Events says "No events found"
Monitoring > Triggers says "No triggers found."
But I did get a message, there was a problem! Where in the web interface can I find a history of triggers, or events ?
