Oracle availability monitoring
  • kamil.korinek
    • Apr 2020
    Hi all,
    we need to monitor the database availability for report purposes.
    We would like to have item which will connect from zabbix server to database on different server without using zabbix client - connection will go through oracle listener.
    in the target database we need to execute simple sql select, output will be 1 - OK or different number - WARNING.
    I tried to investigate the ODBC option and item of type 'Database monitor' but it seems to me that I am not able to put the connection details (db name and hostanem) as a variable ...
    Is there any easy way how to accomplish?
    Thank you.
