when to use UserParameter or External Script
  • sebd44
    • Apr 2020
    hi experts, i'm new to zabbix, only this week into it
    but now reading, i want to take information from json data and commands from linux devices
    so i made it work, with a external script for get the http code and it worked, but now
    i read about UserParameters and also in there i can put the commands but the parse it's in the preprocessing part
    so what's the difference or advantage of doing in those ways
    please help me to get more clear the things in zabbix
    best regards
  • gofree
    • Dec 2017
    • 400
    in general external scripts or userparamters are used whenever you cant get the data with builtin functionality
    http codes can be obtainesd viat http agent or webscenario
    using native funcionalitites result in less errors and less maintenance , not to mention better performance ( built in capabilities are less resources hungry running (lots of) external scripts or complicated user parameters )
    • sebd44
      sebd44 commented
      hi gofree thanks a lot for the help, now it's more clear what to use
      in which scenarios, thanks mate
