Units Formatting on Zabbix
  • Lyxandrah
    • Apr 2020
    Hey there !
    I read a bit about Zabbix and it seems certains units are supported by default. My issue is the following : I am fetching SNMPV2 values via SNMP. Values are returned as 0000 to 2000. In reality, these values are between 0.00 and 20.0 but usually range in the 14.75 range. I am able to get the values from SNMP (For instance, 1475 which is actually read 14.75) but I am unable to use that values in a graph in Zabbix. It keeps formatting to K unit (Thus showing 1.47K). Now, this wouldn't be an issue but this last digit is important so is there a way I could get Zabbix to show up 14.75 OR the full value (Being 1475) ?
    Thank you !
  • tim.mooney
    • Dec 2012
    • 1436
    Check out the general documentation for items and note the section on "Units", and then follow the link related to "unit blacklisting". It will show you how to make Zabbix stop scaling the number.
