VMware VM CPU Usage % Calculation
  • X3n0
    • Apr 2020
    Hi guys,
    I'm trying to create an item by calculating the CPU Usage in Percentage (%) for the template VM VMware Guests.
    I cannot use vmware.vm.cpu.perfcounter() 'cause I have too many different machines to monitor and couldn't turn-on CPU performance counters per each one.
    I alredy tried calculating it using vmware.vm.cpu.usage[{$URL},{HOST.HOST}] * vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}] / vmware.vm.cpu.num[{$URL},{HOST.HOST}] but it seems like that is not possible to include an "Hypervisor's key" inside a VM Guest template.
    I even tried inserting the item for VM's HV Name instead of the UUID for the frequency's item -> vmware.hv.hw.cpu.freq[{$URL},"vmware.vm.hv.name[{$URL},{HOST.HOST}]"].
    It seems there's no way to make it work.
    Do you know if there any other ways to obtain the CPU Usage in Percentage?
  • uwillc
    • Mar 2021
    Try to follow the guide from https://bestmonitoringtools.com/vmwa...er-vm-vsphere/
    • acapozzoli@vmsistemi.it
      • Oct 2021
      Have you solved? When I tried to use this key vmware.vm.perfcounter[{$VMWARE.URL},{HOST.HOST},”cpu/usage[average]”] but i receive an error:
      Invalid key "vmware.vm.perfcounter[{$VMWARE.URL},{$HOST.HOST},”cpu/usage[average]”]" for item "VMware: % CPU Avarage Calc" on "VMware Guest": incorrect syntax near "”]"
      It's this the correct way?
      Thakns in advance
      • ysus
        • Mar 2016
        • 104
        I know it is too late to replay but the problem might be in quote symbol if you copy/paste key expression from internet.
        • irontmp
          • Sep 2023
          • 98
          Originally posted by X3n0
          Hi guys,
          If you can't use vmware.vm.cpu.perfcounter(), try this formula for CPU usage percentage:
          perl
          (vmware.vm.cpu.usage[{$URL},{HOST.HOST}] * 100) / (vmware.vm.cpu.num[{$URL},{HOST.HOST}] * vmware.hv.hw.cpu.freq[{$URL},{HOST.HOST}])
          Ensure VMware Tools is installed for better metrics, or consider using custom scripts inside the VMs for direct CPU usage data.
