Task Scheduler Monitoring
  • mattia.mbm
    • May 2019
    Hi, i need to monitor a specific task on a windows server 2019.
    Looking around i found some solutions but they seems quite old and with newer O.s could not work...
    So How can i monitor a Task on a windows server?
    With a template or item is fine.
    Thank!!!
  • moradm
    • Apr 2020
    Just use the key eventlog[]. You Need to use an active zabbix Agent for Windows Event Logs.
    https://www.zabbix.com/documentation...agent/win_keys --- here you can find very good documentation on this specific Topic.
    Hope this helps.
    Kind regards!
    • zabbix_IT
      • Dec 2022
      I wanna monitor different windows scheduled tasks on a windows server 2016. Is the use of eventlog[] via item and trigger still up to date?
      I am using zabbix agent 2 and zabbix 6.0.
      Thanks.
