in Zabbix I have 2 triggers for "Last Windows Update". One trigger is for last installed updates older than 90 days. Second trigger is for last installed updates older than 180 days. My problem is when host has last update installed more than 180 days, both of triggers turn on.
I want only one trigger turned on, so if last update was installed 180 days the first problem (trigger) go to OK status and second trigger will turn on.
Is it possible in Zabbix?
Thank you.
Thank you.
