SNMP MIB needs additional formatting
  • handsy
    • May 2019
    I have a MIB value that gives me:
    VENDORX-SNMP-MIB::temperatureSensors.0 = STRING: "[Card-1 Intake : 30 C] [Card-1 Exhaust : 35 C] [Card-1 CPU : 37 C] [Card-1 Switch CPU : 46 C] "
    ...and I want to extract both the "Card-1 Intake" and "Card-1 Exhaust" values. How do I do this in Zabbix?
    Ideally the vendor's MIB would have had each value as a unique OID but it doesn't
  • Hamardaban
    • May 2019
    • 2714
    Use dependent items with regex preprocessing
    • handsy
      • May 2019
      https://www.zabbix.com/documentation...ependent_items
      Thanks I'll take a look
      • handsy
        • May 2019
        OK so I have created a template with a Master Item as Type 'text' as I'm pulling back a string. I then created 2 dependent items to pull back specific characters using REGEX. The problem I now have is that I cannot graph those dependent item values as they have to be Type 'text' like Master
        Is there a way of converting my dependent item values in to numerics?
        • Hamardaban
          • May 2019
          • 2714
          Does the regular expression extract only digits?
          If yes - just change the type of the dependent data elements to numeric.
          • handsy
            • May 2019
            Awesome thank you. All sorted.
            For anyone else who needs to do regex like this in the future, here's what I did:
            • Name - Regular Expression
            • Parameters - (Exhaust : )([0-9][0-9])
            • Output - \2
            I basically used regex groups and selected group 2 of 1 for my output.
