Hey !
I am trying to get all fields of triggers with a host.get using selectTriggers with a search criteria and it only returns me the triggers->triggerid.
Here is my query in perl :
my $json = {
jsonrpc=> '2.0',
method => 'host.get',
params => {
groupids => [ '20 ' ],
monitored_hosts => 'true' ,
selectApplications => 'extend' ,
selectMacros => 'extend' ,
selectItems => 'extend' ,
selectTriggers => [ searchWildcardsEnables => 'true', search => [ description => '*.m_*' ] ],
selectInterfaces => 'extend',
id => 7,
auth => "$l_auth",
What I need is to only get the triggers that have *.m_* in it.
When I extract the results, I only get triggerids ... they are the good one so the search is working... but I also need the description and expression from the triggers.
I also tried with output=>'extend' and it did not change anything...
For those who prefer PHP , here is my PHP code:
$hostList = $api->hostGet(
array('groupids'=>getSieraId(),
'monitored_hosts'=>'true',
'selectApplications'=>'extend',
'selectMacros'=>'extend',
'selectItems'=>'extend',
'selectTriggers'=>array('output'=>'extend','search WildcardsEnabled'=>'true','search'=>array('descrip tion'=>'*.m_*')),
'selectInterfaces'=>'extend')
Please note that using this:
$triggerList = $api->triggerGet(
array('searchWildcardsEnabled'=>'true','search'=>a rray('description'=>'*.m_*')));
works perfectly so I assume this is not something related to my search options...
Thank you.
my $json = {
jsonrpc=> '2.0',
params => {
id => 7,
auth => "$l_auth",
Thank you.
