No Connection between active agent and server
  • ITler
    • May 2020
    I'm a bit desparated. Since yesterday morning I'm trying to monitor windows log files with zabbix server. An old server of us is my test object for an active zabbix agent connection.
    The conf-file looks like this:
    ##### Passive checks related
    ### Option: Server
    #    List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    #    Incoming connections will be accepted only from the hosts listed here.
    #    If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally and '::/0' will allow any IPv4 or IPv6 address.
    #    '0.0.0.0/0' can be used to allow any IPv4 address.
    #    Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.domain
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=127.0.0.1,172.17.248.1
    ### Option: ListenPort
    #    Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    #       List of comma delimited IP addresses that the agent should listen on.
    #       First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    #    Number of pre-forked instances of zabbix_agentd that process passive checks.
    #    If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    #    List of comma delimited IP:port (or DNS name:port) pairs of Zabbix servers and Zabbix proxies for active checks.
    #    If port is not specified, default port is used.
    #    IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    #    If port is not specified, square brackets for IPv6 addresses are optional.
    #    If this parameter is not specified, active checks are disabled.
    #    Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=172.17.248.1
    ### Option: Hostname
    #    Unique, case sensitive hostname.
    #    Required for active checks and must match hostname as configured on the server.
    #    Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=Some Windows host with FQDN
    The name of windows host is equal to the hostname written in conf-file of the agent.
    My server conf looks like this:
    #    Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    ListenPort=10051
    ### Option: SourceIP
    #    Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    and the agent conf from the zabbix server:
    # This is a configuration file for Zabbix agent daemon (Unix)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: PidFile
    #    Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_agentd.pid
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    ### Option: LogType
    #    Specifies where log messages are written to:
    #        system  - syslog
    #        file    - file specified with LogFile parameter
    #        console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    #    Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix-agent/zabbix_agentd.log
    ### Option: LogFileSize
    #    Maximum size of log file in MB.
    #    0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    #    Specifies debug level:
    #    0 - basic information about starting and stopping of Zabbix processes
    #    1 - critical information
    #    2 - error information
    #    3 - warnings
    #    4 - for debugging (produces lots of information)
    #    5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: EnableRemoteCommands
    #    Whether remote commands from Zabbix server are allowed.
    #    0 - not allowed
    #    1 - allowed
    # Mandatory: no
    # Default:
    # EnableRemoteCommands=0
    ### Option: LogRemoteCommands
    #    Enable logging of executed shell commands as warnings.
    #    0 - disabled
    #    1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ### Option: Server
    #    and '::/0' will allow any IPv4 or IPv6 address.
    #    Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Default:
    # Server=
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    ListenPort=10050
    # Mandatory: no
    # Default:
    ListenIP=0.0.0.0
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    # Mandatory: no
    # Default:
    # ServerActive=
    # ServerActive=127.0.0.1
    # Mandatory: no
    # Default:
    # Hostname=
    ### Option: HostnameItem
    #    Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    #    Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    Without a domain environment log monitoring works properly, but with a domain environment it seems that the clients can't connect to zabbix server. To ensure it is a connecting problem I typed:
    telnet 172.17.248.1 10051
    I got a connection. But the zabbix agent can't connect to zabbix server. (There is any firewall on zabbix server. The windows firewall has open ports on 10050 and 10051 for incoming and outgoing traffic.
    Where is my mistake?
